98 blower on an 03?
RE: 98 blower on an 03?
ORIGINAL: Dan04COBRA
Sxynerd, how about giving a reason why it won't work rather than just a No? [&:]
Like DSG said, if the head unit is the same you can almost always get new brackets & whatever else you may need.
ORIGINAL: sxynerd
no
no
His very vague question was answered with a very vague answer. We are not mind readers and can always tell what going on in everyones head when they ask a question. Always give as much info as you can regaurding your problem or question.
It is a used procharger for $1700. By used I mean only about 500mi. The kit is complete for the 98 I don’t know if it will work on my 03 GT. I called procharger and I had to leave a message. I am still waiting for there response. I have a feeling that by the time I get it, the procharger will be sold. :-( That’s why I was asking here. To respond the comment about my ambiguity, I'll provide all of the possible information I can the. I have a 2003 SOHC 4.6l V8 5-speed Mustang GT. The procharger I found is for a 98 GT and I have little information about the 98 other than the procharget was used for about 500 miles on it. My intentions are not disrespectful I just need to know because I would not like to pass this up assuming it works. If you need any other information to assist you further just let me know. Thanks.
you should only need to change the mounting bracket. the injectors pump lines tubing etc should all fit. however if it comes with a chip, it may not work due to it being programmed for a 98 NPI engine. just get it dynotuned, wich you should do regardless.
Dragonus18
09-09-2015 01:21 AM
