DOHC Swap?
RE: DOHC Swap?
the actual swap is easy, everything will just bolt up, where your problem is if you go to a 2003 you basically need to rewire the entire car, engine harness, dash harness, computer , constant controll module, gem module pats system(anti theft system), and fuel system. then your ready to go
RE: DOHC Swap?
The only person on the boards that I know has completed what your talking about is Bramas, PM him and im sure he will answer any quistions you have, Not too many people have attempted many swaps... maybe a little over a handfull... Goodluck if you decide to do the swap.
RE: DOHC Swap?
If you go after the 97 cobra engine it will be fairly straight forward. If you find an 03 cobra engine it is a lot more complicated process. For the cost it would most likely just be cheaper to start with a 97 cobra engine.
RE: DOHC Swap?
ORIGINAL: oxfordgt
Its cheaper to buy a cobra
RE: DOHC Swap?
ORIGINAL: czwalga00gt
You can get completeB-Heads with camsfor 250$. Wiring harness, intake manifold,timing cover and what not can be had fairly cheap. Its a good move if you're putting a new shortblock in. Not really worth it otherwise though.
ORIGINAL: oxfordgt
RE: DOHC Swap?
ORIGINAL: oxfordgt
RE: DOHC Swap?
ORIGINAL: amoosenamedhank
I wouldn't waste my time parting it out like that. I would just buy a complete engine. That way you already have the aluminum block and forged crank. It'll will be a lot easier to start with the complete engine.
ORIGINAL: oxfordgt
Why buy a non-forged engine? For the amount a new 4v long block will cost; you could have a built engine good to over 1000 hp with 03/04 cobra heads.
