Help! Pictures included, 56k warning
RE: Help! Pictures included, 56k warning
try switching your fuel pump relay with a similair one such as the a/c one just to see if this works. first of all tho you should test light the hot wire at your fuel pump when your key is cycled on. if there is power and still no fuel pressure your fuel pump is more than likely bad. and you should be able to find a vaccuum diagram somewhere on the internet.
It was the inertia switch. Now the car is dying because of the vacuum lines and there's a ****ton of blue smoke coming out of the passenger side. What do you guys think? Valve cover leaking?
