clutch adj
98 gt how do i adjust the clutch cable
RE: clutch adj
here's how I adjusted it on my 01, maybe it's the same maybe not, but here it is:
Get upside down under your dash. Follow the clutch pedal up to the firewall. You see a rod that kind of goes toward the gas pedal area. Attached to it is a white plastic gear. It should be a half circle or so. Follow the teeth around toward the fire wall. You'll see a little block of plastic with a couple of teeth on it that holds that gear in place. Put your finger on the back side of that little block of plastic, push down toward the floor board. You should hear a loud noise (careful though, scared the **** out of me) which is normal, the half white circle will release and any pressure on the clutch will release. This took my clutch release point from nearly the top of the pedal back down to the middle of the pedal where it probably should be. That little white block will take a little nuts to push on, so don’t be afraid or think it’s stuck. |
RE: clutch adj
dont even have to go to that much trouble......just pull up on the clutch pedal.
RE: clutch adj
Yea, but takes the risk of busting those teeth off and having no way of adjusting it. But to each their own.
RE: clutch adj
ORIGINAL: NeedStangSpeed Yea, but takes the risk of busting those teeth off and having no way of adjusting it. But to each their own. |
RE: clutch adj
i guess that is not my issue it is about 1/2 way or lower i am having trouble going from 2nd to 3rd it feels like it goes in but i get neutral if i go to forth then down shift to 3rd it goes in so i don't know ..it is a steeeda short shifter
RE: clutch adj
Maybe you've got worn synchro's, mine was doing that into 2nd and 3rd, so I pulled the tranny and had it inspected and that's what the tranny guy found.
RE: clutch adj
is that a major job
RE: clutch adj
ORIGINAL: bustoff is that a major job |
RE: clutch adj
went back to stock shifter ...all is well...go figure
