BUILT 4.6?
Old 08-05-2007, 12:31 PM
mrounds06
mrounds06's Avatar
Default BUILT 4.6?
i blew the motor out of my 2000 GT. i want to build but dont know what i should go with. i was thinkin a forged vt shortblock, pi heads and comp cams 262ah. anyone have any opinions on what i should do. i have around 4700 to play with which i dont htink that will get me far. please help me
mrounds06 is offline
Old 08-05-2007, 01:01 PM
JimboGT01
JimboGT01's Avatar
Default RE: BUILT 4.6?
if you do it buy yourself that 4700 might stretch far enough but it will be close...
JimboGT01 is offline
Old 08-05-2007, 10:57 PM
Jcelli04
Jcelli04's Avatar
id suggest you check out MMR (modular mustang racing). they make some good stuff at a reasonable price. also i prefer VT cams over comp. they have less problems with PTV contact. depending on what you plan on doing VT has N/A blower and turbo cams i believe
Jcelli04 is offline
Old 08-05-2007, 11:05 PM
jpmustanggt
jpmustanggt's Avatar
Look at MMR or Modular Powerhouse. They both make quality shortblocks, MMR is a bit cheaper but you can't go wrong with MPH.
jpmustanggt is offline
Old 08-06-2007, 01:46 AM
mrounds06
mrounds06's Avatar
thanks for the info. im lookin at a 2003 cobra motor. what am i going to need in order to complete this setup. will it bolt up to my gt exhaust and will i have to upgrade fuel lines?
Old 08-06-2007, 09:47 AM
JimboGT01
JimboGT01's Avatar
Do a search for the 4v cobra swap...i know you will need the ecu and you will probablyhave problems along the way, but of course you have problems even dropping in the 2v so....It all depends on what you want. 4v>2v but you can make big power on a 2v also...
Are you going to do this yourself?
Old 08-06-2007, 09:49 AM
nanaki
Retired MF Moderator
nanaki's Avatar
cobra swap is more trouble than it's worth. you can get a built motor ready for 900HP from MMR for $2800. heads and cams won't be a bad idea either.
nanaki is offline
Old 08-06-2007, 10:47 AM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
ORIGINAL: nanaki
+1 get a built block with some nice heads and cams. that way if there isnt enough left over youll probably be over 300whp N/A (assuming full bolt-ons) or close to it, and when you go F/I in the future.. you have a forged motor, heads and cams so you can run alot of boost. or you could go the other route, find a lightly used 4.6 and S/C it
2002GTAUTOVERT is offline
10-09-2015 03:27 PM
lincolnshibuya
10-06-2015 08:45 AM
1Bad71
09-30-2015 07:37 PM
Drastang
09-30-2015 03:48 AM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Quick Reply: BUILT 4.6?
