I need suggestions on brakes
RE: I need suggestions on brakes
http://www.buyfordracing.com/shop/index.php?cPath=6
here are a couple to look at, i bought the limited edition bullitt package which they dont offer anymore, but the cobra ones are the same except they say "cobra" instead of having a pony on them. i would highly reccommend the 2 piston cal., 13" rotor upgrade. for $100 extra they threw in cadmium plated brembo rotors.
you will NOT be disappointed, trust everyone that is saying that
As much as I'd like to upgrade to the cobras, I can't afford to at this moment. The problem I have is when I step on the brake, the car whobbles because the rotors aren't turned. The mechanic can't turn the rotors because they are too rusty. So, I want to get new rotors, for now. I just want to know if there are ones out there, other than the ones I mentioned earlier, that are a good value. Oh, and the other reason I need save a little money is because my check engine light just came on and I have a sneaking suspision that it is my cat's. If that is the case, it might be time to get some prochambers as well. Any other suggestions for rotors would be great and thanks a lot to everyone that has posted already.
have you checked pricing at your local autoparts store, they would probaly be a lot less expessive and serve their purpose good enough for yousince price is a little bit tight right now, IMO i wouldnt spend 200 on rotors when 2 piston calipers and 13" rotors are only 200 more
good luck
good luck
09-25-2015 06:42 PM
