tranny fluid leaking
RE: tranny fluid leaking
rear seal, pretty quick fix. Jack the car up in the back, unbolt the driveshaft pull the old seal out(watch for fluid none should drip if its high enough) tap new seal into place, insert driveshaft, rebolt using RED loctite and lower onto the ground, check for leaks
09-25-2015 06:42 PM
