S/C
RE: S/C
ORIGINAL: jpmustanggt
What kit did you get? It oughta come with spark plugs and stuff. Wheres the kit from?
8banger if you're running your car hard without a dyno tune to check a/f then you're crazy.
Edit: Add a new fuel filter once you change out the stock GT pump for your new one.
RE: S/C
the only thing worrying me on the install is the fuel pump never dune that b4 how hard is it and is there any thing i need like silicone to make sure no leaks.. sorry if its a stupid ??? just want as much info as i can get. thanks jeremy
RE: S/C
RE: S/C
you should def get a dyno tune. if one thing is off you could blow that motor. at least get it on a dyno and see if your a/f is ok. if it is no need to tune.
my vote goes for tr6s @ .35. thats what i just bought to put in my car with my KB 1.7
RE: S/C
already have it set up at nextgen... they are a diablo dist. so it works good for me they do a base price of 350 unless the need to fix it the price will go up does a 350 base price sound good.
Soldier GT
08-12-2015 03:46 PM
