T.B. install
RE: T.B. install
The throttle cable just slides right out, you just have to take a little tension offof it first. Its the cruise control cable that you have to worry about, its really easy to break the plastic piece at the end. If you are standing at the passenger side of the car looking at the engine pull the CC cable towards you to release it from the little cam it snaps on to.
RE: T.B. install
Explain "slides" right out. The CC cable was easy, slight pull upward and it came off. Now the throttle cable seems to have metal end on it, I know I have to open the TB to release tension but I don't know the way to remove it. Do I slide my finger under the cable and move it toward to passenger fender? Please help...
Thanks
Thanks
RE: T.B. install
Thanks for the replies!
I installed the TB about 7 hours ago. I had no problem getting the throttle cable off, but putting it backon caused me to stop and take a step back. But I got it! The only thing that sucked about the install was I wanted to put on my Green filter at the same time, but the filter was messed up from the factory. It would not fit on the MAF part of the intake.[:@]
So now I have to send itback to where I bought it and WAIT for a new one. Oh well....
09-10-2015 08:39 PM
