best guages to get?
RE: best guages to get?
ORIGINAL: Mark99GT
Id get a fuel pressure gauge over avolt gauge. If your're planning ahead the fuel pressure gaugeis a good idea anyways--as is the air/fuel. As stated above, you need to spend some coin to get a good a/f gauge.
ORIGINAL: BigRed03GT
thanx guys, i guess i'll leave the air fuel ratio and boost guage for later on, cus i do plan on gettin a kenne bell s/c in a few years. so for now i'll stick wit water temp. oil pressure and maybe volts.
Look into electric gauges for the oil pressure andfor the fuel pressure, ESPECIALLY the fuel pressure. You do not want a gasoline line routed into your cabin, id stay away from running a mechanical oil pressure in the cabin too. Electric gauges costa little more, but leaking oil or gasoline in the cabin from a mechanical gaugecan be very dangerous (inhalation, fires, mess...etc).
Dearborn5.0
08-09-2004 10:42 AM
