I have a chance to buy analternator and awater pump pulley from a 2001 Bullitt.
My question is, will it work on my 2002 GT? Again it is just the two (2) pulleys.
Any help would be great!
Will the ratio still be the same? Will you need a shorter or longer belt? will it cause more or less water flow or charging from thealternator?Usually you match up your pulleys with the crank pulley, such as inan underdrive pulley system.
