rear suspension set up need info?
I am planning on doin the eibach sportlines, Lakewood shocks/struts, lakewood traction action lift lower control arms replacement, and lakewood upper control arms. Along with Ford Racing caster camber plates and alignment. Would this be a good set up for light drap racing? I plan on running this will full bolts on and a 100-125 fogger setup.
Should I go with the sportlines or drag kit? I want the ultra low stance of the sportlines but the performance of the drag kit.
RE: rear suspension set up need info?
ORIGINAL: GhostRider02GT
even the drag kit?? I have been told by my local race shop that the drag kit was great for the track?
I have a cheap drag setup and I'm pretty low (about 1.75"). Front: lakewood 90/10 drag struts, 4cyl fox body springs (cut), no front swaybar, Rear: Tokico (bullitt shocks), FRPP "C" springs with the dead coil cut. Pics in gallery
ORIGINAL: code3GT
Any type of lowering spring will hurt ya at the track.
I got a decent drop out of my fox 4cyl fronts and roush racing d/r springs in the rear. its not ultra low, but it looks just right to me.
Any setup that has you almost dragging the ground like a low rider cruising down a south L/A street isn't going to work well for drag racing.
ORIGINAL: 2000GT4.6
ok ok, how bout this, sportlines up front with lakewood 90/10's, and the drag kit out back with this lower control arm set up http://www.jegs.com/webapp/wcs/store...53297_-1_10441I have a "better" control arm that I could lower if need be to my desired height? Would this be better?
