Built 98 cobra..how much nitrous?
Hello everyone...I am new to mustangs so hopping for a great experience[sm=americanasmiley.gif]
I just bought a 98 cobra with a built stroker (302)....the motor came with a flat top CP pistons ( stock compression), Manley Rods, and of course a forged crank.
It also has has long tubes, full exhaust, and a Lightning MAF..
The question is..
How much of a nitrous shot do you think the engine can take?...or what are the maximum gains I could get with this compression? since I know nitrous likes more compression.
Fuel feeding is no issue here..I can upgrade the fuel system
Thoughts are appreciated
The question is..
RE: Built 98 cobra..how much nitrous?
I would start with a 125 shot, when you feel comfortable work your way up to a 175. Spray more depending on how the motor and fuel system react, have fun with it, only push it as far as you can afford to fix it!
Code:
The problem will not be your built motor, more likely something later in the drivetrain (axles, u-joints, transmission). If you decide to go with 200+, then invest in a progressive controler or go with a 2 stage system.
