emergency brake problem
so i lowered my 04 gt and ever since when i hit the breaks hard and the car like tilts, almost, the e brake light turns on until the car settles toa level position. i tried adjusting the switch under the glove box and i can't seem to find some sort of adjustment on the cable. any help on what may be happening to me? thanks
RE: emergency brake problem
The e brake works from a cable so hitting the breaks won't effect it at all. Sounds like you have a caliper that's not working. You say the car leans? Does it pull? You should inspect your rear breaks.
yeah check em all the calipers have that spring to keep the hand brake cable in line and may be messed up my caliper was seized up and the spring to my suprise just fell out so it was not working well either ...but the frozen piston wore my pads and rotor so save some cash and check em ..rogerwilco out
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
