FRPP pedal install Q?
Hey everyone, just got my FRPP pedals from AM. Was wondering if you have to take the accelerator out to get the stock pedal off and the FRPP pedal on? Anyone that has intalled these, is it very difficult? Just tryin to figure out what I'm in store for. Thanks.
RE: FRPP pedal install Q?
There is a pin that you have to remove first to be able to get the old gas pedal off.
It is pressed in and you need a punch and hammer to get it out.
I got pissed off after all the time I spent on it and finally cut it off with a dremel.
I put the new one in place and used a bolt of the same size with a nylock nut and it was done.
I just put a screwdriver in behind the dead pedal and busted it loose. The new one just snaps in place in the bracket. This one is the easiest.
You can boil the others to make the rubber more flexible but I used a hair dryer and it worked great.
Very tedious installing the clutch and brake pedal but these pedals look great when they are all on.
Good Luck
Good Luck
AmericanMuscle4.6GT
11-10-2015 02:06 PM
09-08-2015 11:50 AM
