Shifter Grinding
Old 08-23-2007, 01:45 AM
MCanavan6
MCanavan6's Avatar
Default Shifter Grinding
A while back I installed an MGW short shifter in my 01 GT (Trema 3650 transmission) and in the last month of so the shifter has been grinding. It only happens going into 3rd from 2nd but it like stop and then needs a little extra umph to get it in and when it pops in it makes a small grinding sound. Any idea on what this sound is and how to fix it?
MCanavan6 is offline
Old 08-23-2007, 03:03 AM
FDNYBullitt
FDNYBullitt's Avatar
Default RE: Shifter Grinding
Sounds like the infamous T-3650 3rd gear synchro going bad on you. There is a TSB on these trannys for this problem, seems they used really shi**y parts when first assembled.
FDNYBullitt is offline
Old 08-23-2007, 04:32 AM
doug0122
doug0122's Avatar
i have the same issue...i guess this tranny is junk for some reason....upgrade or go get the synchros installed...thats about all you can do as far as i know
doug0122 is offline
Old 08-23-2007, 11:37 AM
MCanavan6
MCanavan6's Avatar
you guys have any more information on this?
Old 08-23-2007, 11:09 PM
slickrick06
slickrick06's Avatar
man, i blew my syncho in third gear as well. and was in perfect time because i found a t-56 out of a 03 cobra. got it really cheap and has a pro 5.0 shifter in it. havnet had any problems since then.
slickrick06 is offline
Old 08-24-2007, 01:02 AM
MCanavan6
MCanavan6's Avatar
so I blew the third synchros in my tranny?
Old 08-24-2007, 01:51 AM
FDNYBullitt
It may not be blown but its on its way. The bullitin for this is TSB 04-15-6, grinds into 2nd or 3rd gear, jumps out of 2nd or 3rd gear, use replacement kit # 3R3Z-7124-AD to replace 1-2 and 3-4synchro assemblys, 1-2 and 3-4 shift forks. Plus a bunch of other parts. If your car is still under warranty then bring it to Ford for the rebuild, no cost to you, if no warranty then your SOL on this, good luck.
Old 08-24-2007, 11:37 AM
MCanavan6
MCanavan6's Avatar
Do you think I should fix this now or wait til it goes?
Old 08-24-2007, 02:17 PM
langod
langod's Avatar
FYI: When I had this done (under warranty) the dealer said it would have been about $1500 if I had paid for it myself. But it fixed the grind. I was getting it on 1-2 and 3-4 shifts in cold weather. It's been 3 years and 25000 miles with no probems since.
ORIGINAL: FDNYBullitt
langod is offline
Old 08-24-2007, 02:23 PM
01snake
01snake's Avatar
HAHAHAHAHAHAH
i had the same problem.
i missed 3rd one time really bad. and i have a steeda short throw. and i had a problem goin from 2nd to 3rd
like when i went to shift it wouldent go in the i would have to let out then oush it in
well one day i raced my friend and dame thing happened and i slammed it in and blew my cluch up, and the dealership had to regrind my flywheel[:@]
01snake is offline
Quick Reply: Shifter Grinding
