Question About Refilling Tranny Fluid
Hey guys, I just wanted to aska fewquestions about tranny fluid.
Where/how can I check the level?
How much is needed?
Where do I fill it from?
Thanks.
How much is needed?
Thanks.
RE: Question About Refilling Tranny Fluid
there is a "fill" and "drain" plug marked exactly like that under and on the side of the trans. just use a half inch drive ratchet to unscrew. The proper amount of oil should be right at the base of the fill plug. You must use a pump to push fluid back in the trans.
LivingInThePast
09-16-2015 12:20 PM
jaiidutch
09-14-2015 10:29 AM
