Rim help
RE: Rim help
ORIGINAL: 2000GT4.6
Don't you all think he would be better off with a 8 inch rim on the back for a 275? My 275s are fitting on a 7 inch rim atm, seems like a 8 would be about right, but a 10 should be streching them a bit on the rim?
RE: Rim help
ORIGINAL: doug0122
what kind of cornering can you expect with 4 to 5 inch rims on the front...im sure nothing insanely fast but ive been told anything over 20 will slide you into a ditch...anyone know about that???
and my front rim is a 3 1/2....with no front Sway bar...
RE: Rim help
M/T suggest this.....
"Acceptable practice for rim width is tread width plus or minus 1'.
andapproved rim width for this tire is 7.5 to 9.5....but then refer to the top statement....and tread width is 10.4....for the 275....
RE: Rim help
so to be on the safe side, if i do get the 15x6 what sizetire would be the best medium for draggin/daily driving? im set on the 15x10 with a 275 DR, but now im just tryin to figure out the front.
if i have the 1.5" drop, will i have any problems fitting a 275x60 in the back?
RE: Rim help
ORIGINAL: JJ03MustangGT
yes sir....i have a 295 now, and i have more than enough room for a 315. if i put a 315DR on my car, and hook just right at the track, my rearend will go pop!!!!
If your running a nitto you PROBABLY don't have to worry about this... but it could aways happen. Anything stickyer than a nitto and your taking your chances if you launch too hard.
For the record, I have left at 4000 and 4500 RPM on MT ET streets with my current power level, and the only 8.8 mod being the t/a rear girdle and studs.
RE: Rim help
i guess thats good to know. im gonna stick with the 275 for money reasons as well as weight. the only question i really have is that what sidewall most people are runnin in the front?
