Crankcase Breathing, Best way?
I've seen2 ways of letting your engine breathe with a supercharger but was wondering what would be the best way? #1, Use an oil/air separator between the line and still let it feed into the TB or #2, remove the PCV, use a breather can and route both valve cover hoses into the breather can, therefore releasing the gasses into the atmosphere. Im leaning more towards #2 but wondering if not having vacume to actually pull out the air from inside the engine will be a problem and also with no PCV there will be alot more oil passing through eventhough the oil catch can will hold it there. Any suggestions appreciated thanks.
NeoTokyo
08-22-2005 01:46 AM
