enigne bogs
Old 08-24-2007, 11:32 PM
bonds Stang
bonds Stang's Avatar
Default enigne bogs
i just installed the 75 MM accufab TB and plenum with TB and Intake spacers, and once in a while when I floor it, it will hesitate for a second then take off. it's not everytime. Could this be because Im running lean Or maybe the computer hasn't had time to adapt, since I haven't done a full drive cycle yet. Only drove about 30 miles since I finished it.
I went with the 75mm combo since I plan on going with a FI setup and and doing a PI swap in the future.
bonds Stang is offline
Old 08-24-2007, 11:40 PM
LetThePoniesRunFree
LetThePoniesRunFree's Avatar
Default RE: enigne bogs
Did you disconnect the battery for40 minuets or so after the installto clear the ECU?
LetThePoniesRunFree is offline
Old 08-24-2007, 11:44 PM
bonds Stang
i had the battery disconnected during the whole swap.
Old 08-24-2007, 11:49 PM
LetThePoniesRunFree
Run it a little more than 30 miles and post back if the problem hasn't corrected itself.
6bangr
02-15-2016 07:40 AM
Seanam
10-04-2015 10:15 AM
Daddys Girls GTs
09-14-2015 08:46 PM
nickpeck28
07-05-2004 10:45 PM
Meaty84Stang
05-05-2003 02:10 AM
Quick Reply: enigne bogs
