Speedo intermittent
Speedo intermittent
My speedometer sometimes does not register properly. Somedays it says 0 and other days it maybe 20, 40 whatever, but I know that it's not right. Is it possible that the gear is slipping on the cable or just not making good contact withthe tranny gear? It is a 96 GT auto with 150,000 miles on it. Anyone had this same experience?
RE: Speedo intermittent
Good thought about the gear in the cable. You should go under your car. Its got one bolt holding in a retainer for the cable pull it out and see if the teeth are fine on it. If not I think you found your problem. there is also a plastic gear on the tail shaft of the transmission so hopefully thats not wron too.
zanemoseley
09-06-2015 12:58 PM
