SUpercharged tune Question
RE: SUpercharged tune Question
It has ceramic bearings kevlar upgraded belt aftermarket impellar and vent ports on the drive side. I had a friend order the parts through his company back home so I got them at wholesale price.
Well the only thing you can do is try it. If it fails...you'll know why. Like someone said before, there's a reason they're so cheap.
The kevlar belt while stronger than rubber will eventually fail after such abuse at 12psi. Should you spin your blower that fast, this is what you'll more than likely see shortly after.
