suspension noise?
suspension noise?
alright so any time i hit a speed bump, or even just a small area in the road thats uneven i can here somethin on my front driver side squeek
sounds like a loose bolt, but yea i'd have no idea where to even start looking
any suggestions?
any suggestions?
RE: suspension noise?
I have a similar problem, start with your sway bar mounts, tighten your upper strut mounts and go from there. It shouldn't be your tie rods or springs unless the spring isolator has wore away and you have metal on metal contact...
E.
E.
I have that same problem, it makes the sound when im going around an off camber RH turn. It does sound like metal on metal, and coming from the drivers front. I'll throw it on the lift and try lubing all the bushings.
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
