FoxLake 2V P51 Intake???
does anyone run this intake or know where i can read up on tests with it...im looking for an intake to go well with a vortech v1 t-trim...anyone know if this would be good for that setup or is there something more ideal?
RE: FoxLake 2V P51 Intake???
ive been told its a good swap for both... i have seen it on both... i talked to foxlake and they said it will work real well on blown cars as well.... that is the manifold i plan on buying next monday.
foz lake claims 87 hp to the rear wheels with their intake, stage 2 heads and cams.
N/A it kept the 4.6 2v powerband almost the same as stock but gained 17 HP and like 14 HP...I plan on buying one er their power pack
If you are still on your stock internals and are just planning on touching the limits with a S/C, don't waste your time & money.
It's a ton of cash, while it helps...there is far better options for a stock internal 2v.
i dont plan on getting a new intake until after i forge the internals do some head and cam work and prepare to put a vortech t-trim on my car i just wanted to know if this is an ideal choice if if something is better...like the new trickflow intake....
i have seen a video with a strocker motor with the p51 and it made like 680's on the dyno...i have the p51 in my car now with a built motor and it was a day and night diff....i just bought a t trim with air to water intercooler eight rib setup and a 15lbs pully...i will let you know what i put down
"I personally" don't like the P51 on a S/C car because of the long runners. "I" would do the HPS Hardballer intake for a blower application. Logan is also making a new 2V intake, but it too, has the long runners.
