Wierd noise at idle.
Old 09-04-2007, 11:54 PM
MU71L4710N
MU71L4710N's Avatar
Default Wierd noise at idle.
when i start my car i get a pretty bad rattling noise, chills out after a few seconds. it quiets down but its still there. it almost sounds like a diesel engine idling (not nearly as loud or anything, but a constant clacking). it goes away after about 1500-2000rpm driving, and goes to almost nothing once i drive it then park. friend said maybe one of the pulleys is off, i just got the car and they replaced the belt so that could be a possibility? i realize this will be a hard question to answer without seeing the car. reading stuff about camshafts grinding and stuff like that and its flipping me out, i really dont want/cant afford rebuilding this damn motor right now.
MU71L4710N is offline
Old 09-05-2007, 12:09 AM
945LSTANG
945LSTANG's Avatar
Default RE: Wierd noise at idle.
exhaust is probably rubbing on something.
945LSTANG is offline
Old 09-05-2007, 12:45 AM
CobraStangGT16
CobraStangGT16's Avatar
Busted cat? Kinda sounds like my problem....if you ever get under the car, hit the exhaust with the palm of your hand. Be sure to use a wet folded up towel if the car is still hot. If you hear any rattling, follow it to the source...hit the cats a few times, if you have them.
CobraStangGT16 is offline
Old 09-05-2007, 02:31 AM
MU71L4710N
MU71L4710N's Avatar
i got an OR hpipe commin hopefully by friday so that will rule a cat out.
Old 09-05-2007, 09:02 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Depending on your cat-back, the O/R mid-pipe will have a tinny rattle to it & just make things more complicated.
Take a long screw driver while your engine is running & place it to various parts of the engine with it to your ear.If you can't pin-point the noise, start looking under the car...
If you have an aftermarket cat-back, look at all the hangers. Some hangers have set-screws in them that come loose & let the hanger rattle on the exhaust tips at low RPM's.
Dan04COBRA is offline
bjdutch2005
03-24-2017 03:38 AM
TCStangerv6
10-11-2015 05:57 PM
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
Quick Reply: Wierd noise at idle.
