Misting Green Stuff
Old 09-05-2007, 06:34 PM
MU71L4710N
Default Misting Green Stuff
k so i popped my hood when i got to work today cuz i got a bunch of peas stuck right under the hood on that black plastic where the wipers are. anyways...
there was green fluid (guessing antifreeze) misting off the top of te motor kinda. its right where the thick radiator hose connects to a metal thing and that metal thing is sitting on the motor. was told this is the waterpump, and its either a 6$ o-ring or worst case a 30$ waterpump. anyone had this happen before?
MU71L4710N is offline
Old 09-05-2007, 06:42 PM
Cornbread01
Default RE: Misting Green Stuff
do you have the all plastic manifold or the one with a aluminum cross over. if all plastic check to make sure its not cracked. but that is not where your water pump is your water pump is right above the crank pully
Cornbread01 is offline
Old 09-05-2007, 06:44 PM
MU71L4710N
pretty sure its the aluminum crossover. ill snapsome picsand postem when i get back from work im on lunch right now and i gotta head out.
cliffyk
TECH SAVANT
cliffyk's Avatar
Help us out here, what year is your car?
cliffyk is offline
MU71L4710N
my bad 03 gt.
Old 09-05-2007, 06:46 PM
Cornbread01
should be aluminum cross over is the hose tightind down all the did you recently channge the thermostat??? could be the o-ring ontop the thermostat
Old 09-05-2007, 07:22 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
'03 is definitely an aluminum crossover...
cliffyk is offline
Old 09-05-2007, 10:00 PM
MU71L4710N
ok heres the pics. its alum crossover if that makes any diff. its comming fromnear this metal thing thats attached to the rad hose. its spraying up, so its not comming from the rad hose.
http://img413.imageshack.us/img413/8453/85493375oi2.jpg
http://img519.imageshack.us/img519/5917/62468445yx4.jpg
http://img413.imageshack.us/img413/5773/57662056bc1.jpg
pic 2 shows a question mark to whatever this metal thing was that i was told is the waterpump. its comming from inbetween this metal thing and the aluminum crossovers somewhere where this metal thing connects to the motor.
pic 3 = somewhere around there. i couldnt tell if it was comming from the top or bottom of this thing, as it was misting a good 6-8 inches into the air and i wasnt gonna stick my face in a bunch of boiling antifreeze to see where this leak was.
like, what is this metal thing, are there gaskets that could cause this leak, and how hard would this be for me to fix myself?
preciate any input anyone has. im not really wanting to take this to a ford dealer to get robbed out of 900$ for something that probably costs 20 bucks.
Old 09-05-2007, 10:42 PM
Cornbread01
well from the pics i would start by removing the two bolts
Old 09-05-2007, 10:45 PM
MU71L4710N
can u send me the link where its hosted or something, pic is too small to read anything u put on it :-/.
preciate it. im gonna have a good look at it tomorrow afternoon, i work until 4pm tomorrow (usually i dont get out of work till 11, the auto shop is closed and its nearly impossible to do work at dark as i dont have any lights)
Quick Reply: Misting Green Stuff
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
