351w into my 96gt
Old 02-11-2005, 05:27 PM
purple96gt
purple96gt's Avatar
Default 351w into my 96gt
i want to know if anybody has done this swap and what it entails to get it to go in my 96. i would like to have it done before mustang week this year. thanks for the help
purple96gt is offline
Old 02-12-2005, 01:59 AM
BCisme
BCisme's Avatar
Default RE: 351w into my 96gt
basically you'd be redoing the whole car. lots of work but very doable. pushrod motors do get swapped into 96+ cars.
BCisme is offline
Old 02-12-2005, 02:27 AM
USAMuscle
USAMuscle's Avatar
Actually it's not as bad as you might think. Remember the '94-'95 GT came with a 5.0, which has very similar external dimensions as a 351W. You can get motor mounts for a 5.0 SN95 Mustang and they should work. The extent of your work will depend on whether or not you want a fuel-injected or carb'd engine, whether you're going to use a 351 roller block or not, etc. It would be a lot cheaper to build a carb'd 351 but I can only recommend that if you don't have to smog. A fuel-injected 351 would be harder but you can probably get a wiring harness and computer from Ford like the one they used in the 1997 Saleen S351 Speedster or maybe an aftermarket setup. You'll need a beefier tranny if you want a 5-speed or 6-speed, or you can just get a built auto. I've thought about doing the same thing, but it's a PITA to find a 351 roller block...
USAMuscle is offline
Old 02-12-2005, 06:20 AM
purple96gt
purple96gt's Avatar
so id be better off putting a 5.0 motor from a SN95 stang
Old 02-12-2005, 06:56 AM
BCisme
BCisme's Avatar
just buy a nice crate motor, like a 331 or a 347 stroker. but a 302 block based engine would probably be the easiest.
BCisme is offline
Old 02-12-2005, 09:42 AM
chriscindy6369
chriscindy6369's Avatar
I built a 460 bb for my 98 here's a pic. I used 460 motor mounts. email me if you need help
ORIGINAL: purple96gt
[IMG]local://upfiles/6214/A66C39847B0B4E64AE41B0BD42B84F6F.jpg[/IMG]
chriscindy6369 is offline
Old 02-12-2005, 07:25 PM
purple96gt
purple96gt's Avatar
good god thats what i want to do, thats some chevy *** kickin power right there
Old 02-13-2005, 07:38 AM
Aliate X
I ♥ Acer
Aliate X's Avatar
ORIGINAL: chriscindy6369
Jesus christ how did you cram that thing in there.
Aliate X is offline
Old 02-16-2005, 06:10 PM
chriscindy6369
really not too much work to make it fit. I had to go with a Auto but i run a 4500 stall with it. Buy a motor mount kit for under $75.00
guitarman376
09-30-2015 05:54 PM
LiquidDrink
09-29-2015 10:06 AM
deardeeks
03-14-2004 11:27 PM
Mustang88LXKid
02-29-2004 08:01 PM
WNDSOR
01-30-2004 09:47 AM
Quick Reply: 351w into my 96gt
