Lowering the Stang
Lowering the Stang
I think its time to lower the Stang because I look how much better lowered cars look. I am not much of tech guy so is there anything else I need to get besides new springs. I like the way H & R springs look. And much much worse is the ride really once it is lowered? Any suggestions would be geatly appreciated.
RE: Lowering the Stang
if your lowering more than say 1.5in than you will need c/c plates to get the alignment. also much lower than that you will eventualy need shocks and struts as the stock ones will give out quicker. i have teh H&R sport springs with stock shocks/struts and it rides a bit more stiff than stock stuff but the body roll went away. fair trade off if you ask me. i also have the MM c/c plates.
im not happy with my drop, i think its because i reused the stock iso's. the front is a tad bit higher, im not sure if this is how its suppost to be or not. im thinking about taking the front iso's out.
hope that helped.
edit - i should refrase that, you MIGHT need c/c plates if droping 1.5in or more. just watch for tire wear. supersports or sportlines will most likely need the plates.
hope that helped.
I did coil overs and GR-2's - rides better than stock and handles like a **** - I had to get CC plates _ YOU WILL NEED THEM FOR anything more than 1"-1.25" drop. Im happy with it, it has a little more noise at low speeds (on bumpy *** roads). But i did the whole deal shocks and all for 450 bucks - for all four. (removed the rear isolator and got rear shocks) awesome ride
ORIGINAL: andy98gt
Anyone know where i can get some sweet shocks/struts a nice price.
ORIGINAL: mvr
hope that helped.
hope that helped.
