03/04 cobra fuel tank and dual pump
anyone know where i can get this set up for a good price..... code does thr have this set up..... my tuner said if i want bigger number i need to go with 42lbs injectors and suggested the dual pump set up... i am maxing out my svt pump
RE: 03/04 cobra fuel tank and dual pump
If your not already running a 42 lb/hr injector your not maxing out the SVT pump. the SVT pump should max out around the same time as 42s, which is around 500 WHP.
If your using enough fuel for the dual pump setup you need to be looking at 60 lb/hr injectors. Is your car a stock shortblock car? What WHP?
stock short block 38lbs injectors and it made 347rwhp. they tunner said it would be a good idea if i wanted to make 400rwhp to upgrade to the dual pump and 42lbs injectors. and then do a powerpipe and 3.33 pully
I have the 03+ cobra tank and pumps and it's not cheap! If I knew then what I know now I would have gotten the GT pumps and saved a ton of money andwould have been able to support evenmore power.You'll be fine with a svt focus pump with your setup.
ORIGINAL: 2000GT4.6
if you have the stock block still, don't bother with the dual pump setup. buy an intercooler or get meth injection and you'll get another 30-50RWHP.
TfcCDR
09-14-2015 12:08 PM
