PI Intake Swap---How To
RE: PI Intake Swap---How To
You don't have to change your heater core tube, just the rubber part right! The part on top of the motor should be still useable. I think you only need to change the left heater hose on the firewall.
ORIGINAL: 97targa
hey man thanks for the info. im going to be doing this in a few weeks my self. looks good!!
All total.... i think it was about 300.... about 200 for the manifold, and then just misc stuff(30 for intake gaskets, o-rings, 30 for coolant hose). could be less, could be more. and will someone put this as a sticky lol
great post! just wanted to add..... the n/pi have the spots for the sensors and the pi just the one spot you can spend seven dollars and buy a t which screws into the one whole and you can screw both sensors into that. pretty easy and only seven dollars to get the annoying coolant light off . if i know how to get a picture on here i would show you mine
that is not a bad idea, i still have the sensor and never drilled the hole so it should work. you should def throw a picture up so i can see how u did it, and i never get a coolant light on tho.....
