Guys...I need help! FIXED!!! JUST THE BELT!
Old 09-08-2007, 02:47 AM
redmaro1
redmaro1's Avatar
Default RE: Guys...I NEED HELP...FAST! PLEASE!
The wather pump will have a small hole on top and on the bottom right behind the pulley, turn on the car and then check to see if water comes out of the little holes. If water does come out youve found your problem.
redmaro1 is offline
Old 09-08-2007, 02:49 AM
redmaro1
redmaro1's Avatar
It probably be best to replace your water pump. Usually it will start to leak when your pulley starts going out.
Im pretty sure you can install it yourself.
redmaro1 is offline
Old 09-08-2007, 02:50 AM
CobraStangGT16
CobraStangGT16's Avatar
OK wow...thanks. I'll try it tomorrow.
I read somewhere else that the guy isolated the noise by removing the belt and starting the engine....is that safe for just a few seconds to hear if it's there or not?
If it's OK, then I'll do that tomorrow in case I don't figure it out.
Thanks redmaro1.
CobraStangGT16 is offline
Old 09-08-2007, 05:22 AM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: CobraStangGT16
Thanks redmaro1.
So long as you don't run it more than a few seconds this should be ok.
First things first... take off the belt and try turning the water pump by hand.
2000GT4.6 is offline
Old 09-08-2007, 10:11 AM
oxfordgt
oxfordgt's Avatar
I drove my car for a mile with no belt once its fine as long as its already cooled down. It sounds like the water pump is bad. They are cheap and very easy to install. Its just 4 bolts to pull the pully off and 4 bolts to pull the pump off. Nothing is in the way so its easy.
oxfordgt is offline
Old 09-08-2007, 01:25 PM
CobraStangGT16
OK I'll go ahead and check the pump out today.
God, I hope thats all it is. I think I'm just going to sell this thing soon. All this is coming out of my pocket, and I losing money fast. [&o]
Old 09-08-2007, 01:53 PM
djb1187
djb1187's Avatar
yeah when you take the belt off turn the pump by hand to see if it has instant resistance or some play before it turns. thatll let you know if its bearings...it sounds like its gone bad tho
djb1187 is offline
racer02GTstang
racer02GTstang's Avatar
a water pump on a stang is 15 to 20 min max... very easy on the stang... 4 bolts on it and also 4 on the pulley
racer02GTstang is offline
Old 09-08-2007, 01:58 PM
02WhiteGTVert
02WhiteGTVert's Avatar
time for an electric water pump brenspeed has em right now for ~$300
02WhiteGTVert is offline
Old 09-08-2007, 03:01 PM
CobraStangGT16
ORIGINAL: 02WhiteGTVert
****that! I said I was low on cash!
Autozone $45.00 FTW.
Quick Reply: Guys...I need help! FIXED!!! JUST THE BELT!
