pi swap help
pi swap help
im doing the pi swap on my 96 gt im having fox lake do a stage 2 port job and i have a Pro Products typhoon upper and lower intake plus 75 mm throttle body, bbk cold air kit,underdrive pullies, bbk long tubes, bbk xpipe, and flowmasters and 4.10s i need to know what cams i should get for the new heads and if i should do anything else that you guys have had success with like maf, injectors, n2o i plan on dyno tunning also one more q what have u guys done with the egr valve is it a good idea to take it out or should i leave it on
RE: pi swap help
I went with compcams stage 2's for the npi heads, and they pull all the way up to the 6500 revlimiter that tim @ mph set up. Plus they have a decent lope to them. I kept the stock maf and injectors and still made 271hp with non ported heads and stock pi intake.
RE: pi swap help
ORIGINAL: Chris98Gt
RE: pi swap help
I've got npi cams in my pi heads. I didn't know how far I could go with the npi pistons so I went with the lower lift cam. Yes Vtengines.com sells stage one cams that don't require new valve springs but stage 2's do, aswell as new dished pistons if you use the staeg 2 cams with 550 lift thats why I went with the 495 lift npi cams.
RE: pi swap help
ORIGINAL: Yellow_stang
do you know where can i find those at, and you say vt stage 1 ? im sorry but i dont know what that means is that the brand ...
Matt's 95 Stang
10-05-2015 07:16 AM
