accufab tb/plenum combo arrived
I got my accufab combo unit today from AM. Actually, it probably just shipped from Accufab. No instructions. I know this should be an easy install but nothing inside but a part wrapped in bubble wrap and two gaskets and a PCV tube. Shouldn't there be a gasket where the plenum mounts to the intake or do they expect you to use the stock one, if there is one? Not impressed.
RE: accufab tb/plenum combo arrived
Well, I am impressed again. I sent an email to accufab and they got back to me in about 5 minutes. Pointed me to a link on there web site. Mostly for TB install only. Thought I would share it. Good info on TPS adjustment.
http://www.accufabracing.com/article_1.htm
ORIGINAL: Shelbyville
You will see it when you remove the stock plenum.
It stays on so do NOT try and remove it.
The install is pretty easy.
My Combo from AM came wrapped in bubble with 2 gaskets, one for IAC and the other for the PCV tube I think.
No instructions.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
