rear end gear install
I just installed Motive 3.73 gears in my 02 gt...I installed them myself with the backlash set at .006 on an inch. I hear a small whining when i decelerate in 3rd and 4th...It just hums a little, i dont hear any clicks, grinds, or clangs. Anyone have any advice?
RE: rear end gear install
ORIGINAL: oxfordgt
If you ever so lightly touch the gas pedal it goes away.
It's just the nature of the beast I think.
When I was test driving S197s before I bought my 2003 Vert, I would say about 1/2 of them had some kind of gear whine and these were brand new cars.
Also some people are very sensitive toward gear whine and others don't even hear it.
Kind of like o/r pipes [8D]
ORIGINAL: V8Cody
From what I have heard...Motive Gears almost always whine even installed by a Professional.
correct...backlash should be .008 to .010...max....What about pinion depth?Gotta check that to,,,can't just install the oldpinion shim and expect it to be right...Slight whine...should be fine for awhile....
Pinion depth might be the culprit. I haven't done gears in long enough that I've forgotten wheich way it is, but too deep causes whine on decel and too shallow causes whine on accel. At least that's my experience.
I recently had Motive 3.90s installed by a reputable local shop and they have a slight whine on decel as well. It's light enough that I figure it's fine. If the guy were to try to fix it, I'd probably end up with whine on accel or at cruise as a tradeoff. I'm leavin it alone.
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
