need help please racing clutch???
i have not stop having issues since i installed the kit by clutchmaster with a stage 4 clutch stage pp and new throw out and pilot bearing. has anybody heard anything of clutchmaster. my trans is stock and also has a steeda adj cable kit. twice i have had to change the cable, the throw out bearing is going bad again for the third time, and the gears are getting harder to get them in. what could i do to fix this??? could it be to much of a clutch for the tranny?
RE: need help please racing clutch???
i thought it might be a defected p.plate? i really hopeits the adjustment. i gotta take it to steeda and i dont wanna buy a new clutch and p.plate. have you heard anything about clutchmasters??
i have a spec 2 cluch in my car im was having the same problems the gears are hard to get in cuz the clutch cable isnt adjusted right which means your clutch is still engaged a certain amount when the petal is pressed in, then i adjusted it to much making it to tight so the throw out bearing was always riding the clutch giving it a shorter life span and now it squeels when its cold
Stage 4? If it's rated anything like spec, then you have a race clutch. Which means BAD for street driving and slow take-offs. If you try to use a race clutch like a street clutch, you will have problems.
If this is what you have, its probably a combination oftoo much clutch for your car and improper adjustment.
http://www.clutchmasters.com/shop/Gr.../FX400page.jpg
ccdguy
09-19-2015 05:20 PM
09-16-2015 07:53 PM
