Quality Suspension set up for $500?
RE: Quality Suspension set up for $500?
plus 1 on the bilstein goto stangsuspension.com get them for about 528 a set. then later upgrade to some springs perferably a coil over kit. as far as brake cheap and easy stainless steel lines or you could spend more and get 13" upgrade. but before you do that and after you get your shocks(sense that is a must now) can i recremend some gears in the rear get the 4.10's
ORIGINAL: y2kStangGT
what is a subframe connector and what is it function?
also, how do i know if my struts and shocks need to be replaced?
thanks,
thanks,
I was thinking of removing the front all together.
Steering bushings, how much will those effect the steering sense? Also, any way I can "tune" the power steering so its not so "over boosted", would changing the pullye on it have any postive effect?
Pre made SS lines available? I'll get those on order ASAP (completely forgot about them).
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Dan04COBRA
09-30-2015 11:46 AM
