wanting to lower even more
Ok right now I am running H&R sport springs andI would like to go lower andI was wondering would this make the car lower http://www.maximummotorsports.com/ front and rear coiloversalso wouldthey work with my H&R springs or would i need new ones?
Will some one please help me get my car lower!
http://tinypic.com/view.php?pic=rmsnc9&s=2
RE: wanting to lower even more
coil overs are alot of money and you will not be using your h&rs anymore... this will give you the ability to lower your car till your tires hit the fenderwells.... you will need caster camber plates also
I have my front lowered 1.5" and my back .75" with 18" rubber it rides terrible. My front support bar that is underneath the car just behind the oil pan is only 2.5" off the ground! If I went with a 2" lowered set-up it would only be 2" which is just too low!
ORIGINAL: erikanderson
so why is the Coil-Over Kit,withFront, Bilstein Struts from mm only$260.00 what else do i need i know that it is just the front but the rears are not to much more?
Doesn't anyone worry about beef, and power anymore? Do what you want, but to spend all the money and time onsomething that is going to make your car less driveable, just doesn't make sense to me. Throw that extra money under the hood. Looks good with the lowering as is.
Well im 16 so right now im going more for the looks I want it to have a perfect stance i.e no wheel gap like all the really nice euro cars do. Then after I complete that then the n2o comes. Can someone direct me in the way of a good set of coiloversI know H&R makes a good set but does anyone else im looking to atleast go down 2.5inchs all the way around if not more=)
