Vibration in steering wheel???
tonight i was driving my car and it has a vibration in the steering wheel every once in awhile. I thought maybe my wheels needed balancing so i got that done. That didnt help anything. I stopped at a local shop and the guy there told me that i probably had air in my power steering pump? does that sound right to you guys? The vibration doesnt happen at any certain MPH just every once inawhile the steering wheel vibrates.
RE: Vibration in steering wheel???
Does it happen when your driving or when you are stopping? Or both? I had that problem earlier when I'd stop, the steering wheel would shake violently. A $70 replacement of the front brake pads and rotors fixed that.
ORIGINAL: mustang430
tonight i was driving my car and it has a vibration in the steering wheel every once in awhile. I thought maybe my wheels needed balancing so i got that done. That didnt help anything. I stopped at a local shop and the guy there told me that i probably had air in my power steering pump? does that sound right to you guys? The vibration doesnt happen at any certain MPH just every once in awhile the steering wheel vibrates.
sometimes ill drive off and everything is fine. sometimes i drive off and the steering wheel gets a vibration that only gets worse with acceleration. I guess ill just have to check alittle bit of everything till its gone?
well it turns out the mechanic i asked was right on the money. tonight i jacked the car up and started it, then turned the wheel back and forth about 20 times, now its fine. I went for a drive and its smooth sailing now. Thanks for the replies though...
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
09-08-2015 11:50 AM
