Car wont start help!
RE: Car wont start help!
Did you try cleaning yourMass Air Flowsensor? I know my car did some weird stuff when the sensor was dirty. I took it out and cleaned it with sensor cleaner. That helped it out. Mabe your map sensor is broken. Because when I cleaned mine. I left it unplugged and tried to run my car to autozone for the sensor cleaner. Anyways the car barely ran at low rpms. I had to give it some gas. It also stalled at stop lights. When I cleaned it and plugged it back in it was find.
The reason I cleaned it to begin with was that the car was doing some weird stuff when I got on the gas at about50 or 60 MPHor more I felt this pusaltion or something weird. Almost like I was shifting gears but it was not. It was weird. I had the fule lines flushed. I had the injectors checked. If I remember correctly this sensor cleaning did the trick. So that just makes me think maybe your sensor is broken or needs cleaning.
Here is instructions on how to clean it. It does cause idle problems when it is not working right.
http://www.muscularmustangs.com/maf.php
ORIGINAL: rockerrockstar
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
