Tech info 96 GT
RE: Tech info 96 GT
Thanks for all the responses.
This is where I get my first idea about the car....http://www.edmunds.com/ford/mustang/...merreview.html
I also talk to people who have owned them, and the local shops, and they have all agreed on the "eating tires"
It is a stick, it already has an exhaust, and is lowered. The first thing I will do if I get it is to swap out the intake. Then maybe a good set of headers.
RE: Tech info 96 GT
ORIGINAL: AWD TERROR
RE: Tech info 96 GT
ORIGINAL: catch_15
I have a 98, and when my intake cracked, I needed it replaced that day. I paid $250 for an OEM from my local salvage yard who for some reason carried updated Ford manifolds. It wasn't too hard to install, you can do it by yourself with basic tools. I did it in a couple of hours. Other than that, the only problems I've had with my car are small. My tensioner bearings went out and I had to replace it, and my u-joints went bad. Other than that, It's been a very reliable car.
I think a Ford dealer charges that much for a brand new one!
RE: Tech info 96 GT
Just like everyone else is saying, they don't "eat tires." I have a 97 GT and it does just fine. As stated before, just drive it like a sane person and you'll get whatever the tire says you'll get out of it. As for the header idea, if you're going to do that, you might want to do the entire PI swap instead or at the same time. It's a bit more, but if you don't plan on going FI, then it's an easy way to gain 60 HP.
RE: Tech info 96 GT
ORIGINAL: 97targa
OMG they seen you coming!..lol
ORIGINAL: catch_15
RE: Tech info 96 GT
I have a 98 GT convertable that I bought with 17,000 miles on it. It now has 82,000 and is still bone stock. I haven't had any trouble except the gas filler rubber gasket went bad, battery (factory lasted 8 years) and tires. They are great cars but I guess compared to the 99-04's they're slow.
RE: Tech info 96 GT
You said it was lowered a little bit? And it's eating up the tires? It's more than likely that it doesn't havean aftermarket, camber kit, which is no more than $150 max! (Front tires) Check into that. The rear shouldn't ba any problem.
I have a 96 GT also and I lowered it 2.5" with H&R springs and I love it. And the camber angle was almost 3 degrees off!!! Get that put on and you should be good with the tire thing.
RE: Tech info 96 GT
I looked at it, and something just wasn't right. The paint didn't shine like paint should. I took it for a drive with the owner, my buddy in the back seat. It ran great except for a loud bang when I hit bumps.
I got out and started looking over the car again. I noticed a run in the paint on the front bumper and then it hit me. The whole car was re-painted, and covered in orange peel.
I asked about why he put the lowering kit on, and he replied b/c the shocks were bad. (in 60,000 miles?) So I looked under the car and notice the oil pan was scraped up badly. So he either was beating the **** out of it, or decided to run over a cement block.
I would have to say the car was worth $3,500 at the most. So, it looks like my search is still on-going.
