how to beef up 3650
RE: how to beef up 3650
The TKO and T-56 are extremely underrated, just like the 45 and 3650.
A TKO will pretty much take anything a 2v 4.6L can throw at it. Your simply not going to ever make 1000 FT/LBs on a 2v 4.6L. I don't see even a crazy race only build making anywhere near that..
The 3650 is alot better than the 45, but its holding due to luck, and how you treat it. If you were constantly slamming gears/powershifting and pulling 1.5 60' times its only a matter of time before something goes boom.
+1 on not beefing it up... why bother when for what would be around the same price (unless you can find a deal) you can buy a complete transmission thats specifically setup for abuse (tko).
yeah.. the 3650 is complete garbage. my car was pushing 550RWHP 500RWTQ with the stock 3650 and it's still running strong. what a piece of junk!
I think the transmissions are pretty stout as far as just holding power, but if you beat on them every day you will have to put synchros / second gear/ sliders da da da and it is not cheap.
REad this:
https://mustangforums.com/m_3706991/tm.htm
If i planned on buying a Tko I wouldn't do it untill the one you got now breaks... ya never know it may last forever
REad this:
ORIGINAL: 2000GT4.6
And I had always planned on a viper spec T56 with 3.90-4.10's. I liek with the 6th gear .50 and 4.10's your doing 85 MPH at like 2300 RPM. One thing I like about the 3650 is its first gear ratio. The 3650 with stock 3.27 gears has a higher ratio than a T56 with with 4.10's.
The 3650 is def. better than a T45 no doubt, but if you are grabbing gears, ripping on her like its a mustang, and running around on slicks...you will eventually break the sob. My T45 just went out and i picked up a beefed up T56.
Damn you guys talk alot of sh** about the 3650. Look at the T5. Look at the T45. the 3650 is a GIGANTIC improvement over those transmissions. they're not garbage,i've beat the hell out of mine and it still holds up strong. and if you're really worried about breaking a manual trans,and pushing "1000rwtq",you'd probably be better off going with something like a built AOD.
