Weight reduction? - Page 3 - MustangForums.com
Old 10-02-2007, 11:56 PM   #21
MU71L4710N
Default RE: Weight reduction?
Quote:
ORIGINAL: 02gtvertible
so basically its not worth my time unless i go to the extreme with it?
ehhh...basically. with the money you spent doing all this stuff you could blow or atleast spray your car which would make a much bigger difference in ET's than a couple hundred pounds of weight reduction.
MU71L4710N is offline   Reply With Quote
Old 10-03-2007, 12:49 AM   #22
jEEd
I ♥ Acer
wow and i thought my diet was extreme! haha i weigh about 150lbs right now...
jEEd is offline   Reply With Quote
Old 10-03-2007, 01:16 AM   #23
SN95FoxII
The biggest weight reduction you can do and its by far the one you will notice the most is changing your rims.Its also the most overlooked part by far. Think ofall the rotating massyou will be cutting down onper rim if you did some welds or centerlines.
SN95FoxII is offline   Reply With Quote
Old 10-03-2007, 01:36 AM   #24
Ehmark
Your car weighs 4490? That must be a hell of a sound system.You could get a new k member ,an aluminum block flywheel and driveshaft then some race wheels and ditch some of the sound system. That would definately take off some weight.You could also put fiberglass body parts on.But that is all pretty pricey.
Ehmark is offline   Reply With Quote
Old 10-03-2007, 04:33 AM   #25
ford88
thats what it said in the door jam its a 97 convertible gt ... it was something like rear weight 2070 front weight 2420 something like that then there was a full weight which showed 4490 lbs
and its all stock...
ford88 is offline   Reply With Quote
Old 10-03-2007, 06:43 AM   #26
MineralGrey
MineralGrey's Avatar
Quote:
ORIGINAL: aking287
Yeah that guy isn't that bright. I gallon of gas weighs anywhere from 5.8-6.5 lbs. Less than water, which weighs 8.3 lbs per gallon.
Yes you are right, I was looking at the wrong equation haha, o well you still get the picture, had my numbers wrong. That weight also depends on the refinery it was made at and also the grade of the gasoline.but just take the average and use that.
MineralGrey is offline   Reply With Quote
Old 10-03-2007, 09:58 AM   #27
01GT4.6
01GT4.6's Avatar
http://forums.modulardepot.com/drag-...p;pagenumber=2
this should be all the info you need.
01GT4.6 is offline   Reply With Quote
Old 10-03-2007, 10:50 AM   #28
MrChubs1
Quote:
ORIGINAL: ford88
I think you're looking at the maximum rated vehicle weight, not the actual weight.
MrChubs1 is offline   Reply With Quote
Old 10-03-2007, 11:30 AM   #29
racer02GTstang
yes, thats the max rated... it is much lighter than that though. should be alittle under 3500 stock...
racer02GTstang is offline   Reply With Quote
Old 10-03-2007, 11:31 PM   #30
piledriver
Banned
that weight is the car plus the payload... My 03 vert weighs around 3450.
piledriver is offline   Reply With Quote
S197 Parts baddog671 Parts For Sale 20 07-26-2016 01:20 PM
So who wins uedlose The Racers Bench 4 10-01-2015 08:31 PM
The Ultimate Debate: Mustang V6 vs. Ford Focus St jar_are_red New Member Area 3 09-24-2015 07:03 AM
revolutionary new diet 2015 99GTvert Off Topic 5 09-21-2015 09:34 AM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! [email protected] Steeda Autosports 0 09-08-2015 11:50 AM
1997, 2002, 96, biggest, cobra, crankshaft, mustang, reduction, weight
Featured Sponsors
