Installing MAC LT's and Prochamber
For a 2004 Sonic Blue GT 40th Anniversity Edition,
I've had these parts for nearly a year and I finally have some time to put them on. I've looked at certain websites about how to install the new headers and all of them advise to raise the engine about 6" or so. My question is: is it easier to raise the engine or drop the k-member? Also if raising the engine, what tool will unbolt the motor mounts? And, is there a certain way to drop the k-member?
I do have the Steeda o2 extensions, and a pred 2 tuner.
Any advice will be greatly appreciated!
RE: Installing MAC LT's and Prochamber
the install is not easy, that being said it will be "quicker" to lift the motor. but "easier" to get to the headers in and work with them if you drop the k, but dropping the k is a adventure in itself. i watched yelw02gt install his bbk's by lifting the motor up, still took two days whole days with 2-3 people working on the car at any givin time.
but most shops will quote you 800+......... F that
Drop the K member. Don't even think about trying to get them in by lifting the motor. I know there are people on here that have done it by lifting the motor, my kudos goes out to them. For the extra hour or so it takes to get the K out of there, it is WELL worth it. Also a ratcheting wrench will help a lot to get to some of the header bolts. Also make sure you mark on your subframe what position the K is in....putting your front suspension back in crooked is a bad thing. The biggest problem I ran into was having tools all over the place..took me 6 hours on a lift with one friend helping.
ORIGINAL: dirtystang04
Moral of the story....If you don't want to do it again, do it right the first time.
Order a tubed K its only around $250. You have to drop the k or you will be like some of these guys that it took days just to install headers. Replace the old k with the tubed one you will be much happier in the end. It only take me about 3 hours to install longtubes by droping the k and thats with the car on jack stands.
09-10-2015 08:39 PM
