im at work right now Ill double check but u can follow one to the power steering pump and one to under the power sterring resivor. Ill check the other when I get home
it doesn't look too difficult honestly, but you never know. I think it basically unbolts from the firewall and from the master cylinder and then remove the 4 lines into it. Maybe drain the fluid first. Then hook it all back up and refill and bleed the steering fluid.
