Supercharger Ideas...
#41
RE: Supercharger Ideas...
also another thing to remember is that the p1sc takes an i/c to even make similar numbers that the v2 makes w/o one......there is a reason for that, the oil from the engine cools the blower quite a bit more which increases some power as well as the fact that a v2 intercooled vs a p1sc intercooled dont make the same number (boost being equal).....but like i said, i doubt you wont be satisfied with any of these blowers unless you get a built motor and are power hungry.....then it may bea problem
TO THE OP: didnt you use to have a bullit, and didnt you total it? you look a little familiar
#43
ORIGINAL: JJ03MustangGT
Boost is boost. You get 7% gain in HP for every lb of boost you add. The advantage of an intercooler is you can run highr boost level.
#44
ORIGINAL: FrostByte
Where the hell do you get your info? I think your pulling out of your ***! An intercooler dosnt make more HP by its self. It cuts down on detonation which lets you run higher boost & theref ore more HP. A S/C that uses engineoil will run hotter than a self-contained unit such as ATI.If you want confirmation of this go to ATI's web site & its there in print for you.
An intercooler doesn't "allow you to run more boost" it allows you to run more timing without detonation, by cooling the intake charge. Timing is what causes detonation, not added boost. Adding timing while keeping the boost level the same will increase horspower. This is why many people simply run a snow performance meth injector instead of a FMIC... it does the same thing, allow you to run more timing (abit with chemicals instead of physical cooling).
so far as what ATI says... of course they are going to make claims that it does what they want... its their product. However, engine oil is at maximum about 180 degrees. This is far cooler than the supercharger will get just from natural air compression. Add in that the contained units from ATI have no oil cooling period like engine oil does in the pan... you can see where this is going.
I won't say that vortech is better than ATI or the other way around, but tapping the oil pan is the least of your worries on a supercharger install (10 min job) and at worst the engine oil keeps the blower just as cool as ATI's contained units. It is unarguable however that ATI blowers DO run hotter than the novi and SQ units. Theres a reason that ATI is the only company that offers every kit with an intercooler, and it isn't because they are nice guys.
So far as power to power... I have yet to see a similarly setup ATI car run signficnatly faster times OR make significantly more horsepower than a non i/c SQ or novi 2000 setup. They all seem to make the same power, that is around 350-365 WHP on a stock car and anywhere from 380-420 for a boltons car + 8/10 PSI.
#45
not t mention that the big boy ATI's are intercooled FYI, only the little cheapos are SC for the most part, and notice how the F1 doesnt have that option... that SC is just marketing to sell a supercharger to somebody who doesnt know what they are doing and tell them they can do it 1) with simple hand tools 2) a below average intelligence
most of these units are the same deal, however the novi 2000 will be slow on a stock motor - it begins its intended boost range at around 18 psi - the novi is the best bang for the buck around, however a T trim aint bad... and a ysi .. well you dont want know
#46
ORIGINAL: banned
#47
ORIGINAL: FrostByte
#48
ORIGINAL: 2000GT4.6
I don't agree with that at all. the PS1C, SQ, and even the novi 1000 are great units for the price, espcially on stock motor. Theres no reason to run a bigger blower unless your going to build the motor up, and even then you need to exceed say 520 whp on the SQ and something close to that on the PS1C to max it out. its not a bad blower, or even a bad deal with either supercharger.
ORIGINAL: banned
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
