17x9's on 245/17/45's.......help
I got 17x9" rims.....how well will they fit on my goodyear 245/17/45's? What is the difference between a 245/17/45? Sorry, not too much of a wheel/tire man so i would appreciate the help.
RE: 17x9's on 245/17/45's.......help
so your saying you bought 17x9"s and you have 245/45R17 tires?
if so yeah they'll fit no problem.
what do you mean... whats the diff between 245/45R17 and what? what are you comparing it to?
First of all it's 245/45/17. The first number represents the width, the second represents the height of the sidewall, and the last number tells you the size of the rims.
17x9 will fit 245 just fine. I have 245/45/17 upfront (stock sized tires) and then on the rears I have 275/40/17's. BFG's Comp T/A. I love em and the the 275'sdon't poke out too bad on the 9 inch wide rims. I would suggest a little wider tire in the rear if you have to replace them all, since they all will be off anyways. Also, it's really not that much more ($35 per tire). However, this means that you won't be able to rotate them, that is of course unless you want to poke fun of the hondas running around?!?!
Nice thanks for the help, thats exactly what I needed to know. Snake thanks for clearing that up for me. And I was wonderin the diff between the 40 and the 45, I figured it how now, thanks for the help fellas!
their gonan look a lil small on the rim though....i have 275's on my 9 in wheels and they fit perfectly. but if you dont have the money or alreayd have the tires there wont be a problem puttin em on there
i had 245/45 17 on my 17'*9' on the front but dont go any wider u'll get wheel rubb from steering and i had 275/40/17 on a 10.5' rim and it was alil small so u'll be fine. do it
