spring squeaks
spring squeaks
i don't know what kind of springs the previous owner installed.
everytime i go over a bump or turn right at a low speed my front right spring squeaks. could it be that the strut is loose?
this happen recently. on the highway i feel like the car handle different. it feels like the body doesn't stay with the wheels.
please help.,
thanks.
please help.,
thanks.
RE: spring squeaks
It's probably a bushing that needs replaced.They don't last forever you know.
Did they use "spring isolators" between the springs and the rest of the control arms?
If so,are they in good shape?
RE: spring squeaks
check ball joints, control arm bushings and maybe for broken spring? Most likely your ball joint lube the bushing with silicone spray works the best and if it still happens you will know what to change.
RE: spring squeaks
ball joint is located on the very tip of you control arm, and a spring isolator is the rubber pigtailed piece on the bottom of your spring so it doesnt make contact with the metal of the control arm and make noise.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
