1990 vic to 4V 4.6
1990 vic to 4V 4.6
ok i'm going to say this only a few times
i have a 1990 ford crownvic with a 347 stroker and a T5 5sp and F303 and a maf conversion
i found a 96 mustang that i can get the entire engine harness trans rear end and anny thing else for the swap for 1000$ the only problems i'm facing right now is
the 4.6 is a 2v sohc so with that stock computer what do i need to make it a 4v Dohc
and the other problem i have is what motor mounts do i use
http://www.cardomain.com/ride/2297907
RE: 1990 vic to 4V 4.6
ORIGINAL: mccarterjg
Ohh if you want to pull out your pushrod motor to put in a 4v modular motor, I'm not gonna be shy by telling you that is the dumbest thing I have ever heard and anyone would call you a fool. They are much cheaper, easier to work on and lets face it, we are here for one thing and it's called HP. They make more N/A, alot more!
i'm sorry i didn't clarify.
i'm thinking of puting the engine and transmission from the 96 mustang into my crown victoria
and yes i do know that the windsor blocks are cheap and easy tobuild up but i gues i just like working on my car just as mutch a i do driving it, so i saw the deal and started thinking.
and after i put the 347 T5 in my cv why not start preperations to put in a 4.6 or 5.4,with a T56
and i tried the search function and couldnt find anny thing but one thing on cylinder heads
"Ohh if you want to pull out your pushrod motor to put in a 4v modular motor, I'm not gonna be shy by telling you that is the dumbest thing I have ever heard and anyone would call you a fool. They are much cheaper, easier to work on and lets face it, we are here for one thing and it's called HP. They make more N/A, alot more!"
i have already been called a fool for puting that T5 in my car, now my car is the only one of it's build in the US,
Basically any 4.6 block can be swapped with either 2v or 4v heads. My suggestion would be to just start wtih either a cobra or mark VIII engine. It would make it a lot easier. I wouldn't mess with the 2v to 4v conversion.
Take the 347 out of the Vic and drop it in the 'stang. and Targa,the F303 is the biggest cam FRPP makes. they've got more out there than most people know,hell i had an X303 cam in my '92 (s/c cam)
as far as the 4v motor,it'd be alot nicer in a 98+ Vic. sell the box body to someone who'll put some 24"'s on it and call it a day
ok well i found two 5.4L 4v that will be there for a while
but glad to know if i ever need anny technical help then iknow the people here are more than willing to tell me to be just like everyone else and get a fox body and windsor block
if annyone helpfull sees this and knows what i'd have to do to put the 5.4 dohc in my car with the 96 4.6 sohc mustang computer/ harness then speak out , along about the motor mounts.
kf4mms
04-25-2007 07:16 PM
