My clutch pedle is LOOSE I cant even switch gears with it ?
have no clue ,
I have a stick stang .. its works good
just the clutch pedle is Loose it go's strait ta the floor like a spring is loose or somthing any body got something they can tell me ?
RE: My clutch pedle is LOOSE I cant even switch gears with it ?
have no clue ,
Ok, first they put cheezy quadrants on Mustangs, they are plastic and they break after a while. Notches break off, then you get stuck. It might have broken off and the cable might have came off. Also you might have bent the clutch fork. might have come off the ball. There is alot in play here. I would recommdn checking the plastic quadrant and then if it isnt it, remove the cover on youre bell housing and check in there.
