4.6 out 5.0 in
Old 02-21-2005, 05:56 AM
purple96gt
purple96gt's Avatar
Default 4.6 out 5.0 in
besisdes an engine what do i have to look for to make this swap complete wiring harneses and what else? will it drop right in ? the more info the better
purple96gt is offline
Old 02-21-2005, 06:00 AM
Sick96Stang
Sick96Stang's Avatar
Default RE: 4.6 out 5.0 in
you would be better off modding the 4.6 by the time u spend all the money u get the 5.0 in there you could already have a 12 second 4.6
Sick96Stang is offline
Old 02-21-2005, 10:10 AM
BCisme
BCisme's Avatar
yea you're better off keeping the 4.6. especially if you are on any kind of budget. you'd have to change atoo many parts and the labor would be sky high unless you did it on your own.
BCisme is offline
Old 02-21-2005, 12:03 PM
stonemonk9
stonemonk9's Avatar
Plus the 4.6 is a better motor!!!
stonemonk9 is offline
Old 02-21-2005, 12:05 PM
98LS1
98LS1's Avatar
ORIGINAL: stonemonk9
Haha!
Why not just put a bigger motor in? 347, 351, small block Chebby?
98LS1 is offline
Old 02-21-2005, 02:39 PM
czwalga00gt
czwalga00gt's Avatar
Swapping a 4.6 to 5.0 is a stupid idea. Its bigger but doesnt mean better. If you're gonna do an engine swap put something else in that will have more HP's
czwalga00gt is offline
Old 02-21-2005, 02:40 PM
Acer2428
Site Mod
Acer2428's Avatar
Get a tubular K-member that will fit 96+'s that has the 5.0 mounting points, build yourself a 408 w/ a quality 351w block, some nice heads, etc... You'd have yourself a beast.
Acer2428 is offline
Old 02-21-2005, 02:47 PM
Sick96Stang
Just jack a navigator motor if u wanna do a swap. 5.4L DOHC 32v imagine the possibilties with that motor. Basically you have a cobra motor with .8 more liters.
Old 02-21-2005, 02:55 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
just wiring, cpu, and k-member... and 5.0 exhaust.
mdvaldosta is offline
Old 02-21-2005, 03:58 PM
Acer2428
Site Mod
Acer2428's Avatar
ORIGINAL: Sick96Stang
Wow, this again...
Sure, if you plan on staying N/A it'd be fine. Also, you'd probably want to replace the cams, as Naviator cams are way different than ones you'd want in a stang. No one has yet to explain to me why one wouldn't just do a 5.8L swap??? You can build a forged one for only a smidgen more than a STOCK 5.4L motor...
Acer2428 is offline
Quick Reply: 4.6 out 5.0 in
